Oil Vacuum???
The T Man
First time post and thanks in advance for any advice that you may have too offer.
350 Mercruser Alpha I / Bravo I - year 2001. This has the freshwater enclosed cooling jacket. Here is what is happening. I want from a sustained cruse of about 1500 RPM to about 3000 and I noticed that my oil pressure dropped immediately, like you disconnected the power. I killed the motor immediately and checked the oil but it was up to the top. I noticed that the out drive oil reservoir was low so I added oil to top it off. I went back to ~1500- 1800RPM cruse and the pressure did not drop again. The next day I tried the higher RPMs again but everything seemed fine, until I went to idle. The pressure seemed to be quite low, about 1/8th so I gave it some throttle and to my surprise, the pressure dipped to negative and then quickly came back to the mid range. I am very confused as to what is going an and would appreciate any help.
Re: Oil Vacuum???
Ayuh,... Which is it,..?? It Can't be Both...
I'd suspect either the Gauge, the Sender, or the Wiring is Bad...
The T Man
Re: Oil Vacuum???
The gauges were new with the engine (2001) however, I have a suspicion that this might be the problem. I just can not understand what would make the gauge jump way below zero, it instantly pegs the gauge to a -1/4 if there is such a thing, when I go from an idle to about 2K RPM while in neutral. It just does not sound like any one of the three options that you gave. Do you have a theory as to how I could get a negative reading on the oil pressure gauge?
Re: Oil Vacuum???
Ayuh,... How about a Dead Short in the wrong wire,..?? or an Internal Gauge Issue,..??
It sure as 'ell Ain't the motor doin' it......
The T Man
Re: Oil Vacuum???
Thanks for the help. When I first saw this happening it was not as dramatic as it has progressed to. It has to be a short. Haven't found it yet but I am sure that your diagnosis is correct and thanks.
