Hello all,
I have a 200 hp precision blend Yamaha outboard. I am aware that this subject would have been covered in detail many times but I cannot seem to find the answers I'm needing !! Problem is that the transfer pump will only run for 30 secs or so then stop. If ignition is switched off, then back on, the pump will start again and run for 30 secs. I have removed the tank and ran the pump from a battery and it pumps continuously with no hesitation, even with some resistance from my finger over the end of hose.
I have also done a test during a 30 second run with the engine tank float position and it all seems to work as it should.
Cheers
Cheers
