Oil to gas Mix ratio for Johnson sailmaster engine
J.C.R 7
I have a Johnson OMC sailmaster four horsepower two cycle outboard engine and i dont know the oil to gas mix ratio
JB
Re: Oil to gas Mix ratio for Johnson sailmaster engine
Howdy, JCR.<br /><br />We need the model number to establish the year. From that we can recommend a fuel mix.<br /><br />Good luck. :)
J.C.R 7
the model number is J4RLESR
J.C.R 7
it is a 1990 model engine
gss036
I had a 9.9hp Johnson (white housing)about that vinage and used 50-1. Seems like the manual said 100-1 for slow trolling, but to increase for higher RPM. I used 50-1 all the time and did not have any problems.
JB
50:1 is the correct mix, JCR, as GSS suggests.<br /><br />Good luck. :)
ranger69dv
You got it 50:1 is the way to go, 3 oz oil to 1 gal gas
J.C.R 7
thanks for the help
