Previous owner had oil tank removed and just run mixed gas. Motor is a 1996 Mariner 115 and want to determine if oil is getting to upper main bearing. I found 2 sets of lines, one apparently sends fuel from the enrichner valve to the back part of each cylinder (don't quite know why) and the other set seems to be in a closed loop. It is the latter set of hoses I think are the oil lines (black with yellow dotted stripes on the hoses). Does anyone know how to check for oil pressure into the upper main (i'm assuming the hose that is above the top carb going into the block just under the stator is the one I need)? Also, what is the enrichner valve used for? Thanks.
