Oil Tank Preventive Maintaince
levittownnick
I have a '97 Proline with a 150 Johnson J150EXEUE outboard. I have never performed any PM on this oil resivore or injection system, The questions are: 1) What should be done? 2) How?
Thank you,
Nick
tashasdaddy
Re: Oil Tank Preventive Maintaince
you've been lucky, there are several steps to maintainance. you need to get a manual for your engine, and do all the preventative maintainance. with 273 post, you know we say get a manual. just kidding.
JUSTINTIME
u should flush it, well i do every year on my boat
DHPMARINE
Drain it,clean it,replace the filter.Refill w/fresh oil and add oil to the gas (50:1) until you know it's working OK. (standard operating proceedure any time you interupt a VRO system)
DHP
levittownnick
Thanks,
I will do that as part of my spring maintaince.
Thank you,
Nick
Chris1956
DHP, Is there a filter on the Oil supply system? If so, where is it. I had thought the only filter was the screen on the fuel line that supplies the vapor seperator.
DHPMARINE
There is a filter on the pickup in the oil tank.Often overlooked.
DHP
rickdb1boat
From BRP: # 20 is the filter.....
convert
Chris1956
Gents, Thanks for the info. It was overlooked. If it a "clean" thing or a "replace" thing?
