robalofish
- Apr 3, 2003
- 116
When my engine is off and sets for 1 or 2 weeks it appears that the oil injection still pushes oil into the gas line as evidenced by a lot of smoke at startup and if I pull the enrichment valve hose from top carburetor I see almost pure oil. The longer it sits the worse the problem. I have changed the check valve prior to the gas line tee any other suggestions?<br /><br />1994 200HP V6 CARB
