i have oil leaking out into the wake.there is no leak into the bilge. the plugs show no carbon. the oil dipstick shows clean oil, no water. there is no blue smoke. oil pressure has dropped to a max of 40 psi. valve seals are hard but not damaged. i am losing about 2 litres in about 4 hours of operation,mostly at low speed. there is no visible crack on the outside of the block. starting engine is a little hard.needs cranking a little while.starts idling rough then clears up. 1993 5 l cobra.
it is what i hoped it was not. internal cracked block between water and oil passages.
thank you for any and all help. gerry
