I have a volvo 4.3GLa that has an issue with the oil sensor alarm above the oil filter. The sensor works fine while engine is being started and running. After shutting down engine the sensor will go into alarm about 5 hours later with the key in the off position and no power to engine. I have replaced ignition switch, alarm and the sensor and still have the same problem. If sensor is disconnected the system will still drain the battery. With engine running the oil pressure gague reads between 40-60 PSI. Any ideas where the problem may be located.
