I have been running a 20hp johnson in a tank to try and make it water worthy, and I have noticed that after I run it in a tank, black oil runs out of holes in the lower unit. I was wondering if this is normal. It is coming out of tiny holes above the water inlet for the impeller, probably about 2-3 inches above the cavitation plate on both sides. I have just been idling it in a tank and it probably has lots of carbon build up inside, if I had to guess as well.
It is very cold here in iowa today, I lifted up on my fuel line which was in the back of the pickup today outside with a temp this morning of -4, and the fuel line instantly shattered in 4 places!!!!!!! I guess now I can get a new fuel line and eliminate that as one of my possibilities on why I cant get this motor to work correctly.
