oil ratio??
ccarver
how would i find the oil ratio for a 15hp twin gamefisher.... i dont know the year but my boat is a 77' so idk if the moter came with.. heres a pic
[/IMG]
CATransplant
Re: oil ratio??
The ratio for that motor is 50:1. If you can give us the model number off the tag near the transom mount, we can tell you what year it is. It is one of the Eska-based water-cooled, two-cylinder outboards. Tecumseh engine. Tillotson carburetor with fuel pump built into the carburetor.
When they're running, they're nice, powerful, lightweight outboards. One tip: Never, Never, EVER, turn that engine over with the little wires on the coils mounted to the cylinder head disconnected from the coils. That will instantly destroy the solid state ignition module, for which there are no available parts.
www.searspartsdirect.com has some parts for your engine. You need the model number, which starts with 217 to access the exploded parts diagrams and parts lists on that site.
Other parts are available through www.certifiedpartscorp.com. You must call the number on that web site, with your model number in hand to access parts for your outboard.
ccarver
Re: oil ratio??
thanks.. and the model number is 217-586361 and with the little research i did i think its an 86' many of the parts from sears were discontinued.. :( so i better not break anything.... :D
CATransplant
Re: oil ratio??
Yup, that's a 1986 model...the last year of production for Eska. If you need parts, your best bet is going to be www.certifiedpartscorp.com.
You should baby that motor, due to the difficulty of parts availability. Be especially careful with the ignition system, since those parts are simply not available. Follow the advice I gave you in the previous message.
