Oil Ratio
jamescody
The owners manual for my '82 Mariner 90 HP inline 6 states to mix the oil at 50:1, but on several other boards, people have been saying that 50:1 is inadequate and I really should be mixing at 40:1, regardless of using dino or synthetic....what do you guys mix at?<br /><br />Thanks<br /><br />James
ob
Re: Oil Ratio
Follow your owners manual instructions for mix.
Pursuit2150
Re: Oil Ratio
If the manual states 50/1,why would you want to mix at 40/1? It will foul the plugs, stink and smoke,and build up carbon.<br /> With an oil injection engine (as an example) although the ratio states 50/1, that would be at high speed at slow speed it might only use 100/1. That is why it is called a VRO "Variable Ratio Oil" <br />That's my $.02.
jamescody
Re: Oil Ratio
well the boys down at Scream and Fly have said time and time again that mixing it 40:1 will increase the longevity of a motor tremendously. I was just curious if any engine builders or dealers here would back that up.....I personally mix at 50:1, but if it would help.........<br /><br />Thanks<br /><br />James
ob
Re: Oil Ratio
Excessive rich oil ratio as pursuit mentioned will create excessive carbon build-up and shorten the life of your motor , unless perhaps you scream and fly everywhere you motor.
SpinnerBait_Nut
Re: Oil Ratio
I have a '85 115 Mariner which is about the same as your motor and I always use 16oz of oil for ever 6 gal. of gas. :D :) :D
corm
Re: Oil Ratio
I don't go as fast as the S&F guys, but I run my L6 Merc as hard. I do run syn oil at 40-1 in it.<br />In my 80HP pontoon I run Merc Premium blend at 75-1, I idle around alot. I also use electrode gap<br />sparkplugs in it,not surface gap. The trolling motor on my fishing boat I mix at 90-1. Most motors at WOT need 16-1 and at idle 120-1, 50-1 was a safe all around mix for most all motors and<br />it became the std mix until VOI came along. I ALL<br />WAYS RECOMEND MIXING YOUR OIL AS IT STATES IN YOUR OWNERS MANUAL. My labor is free and parts are at cost so don't do as I do.
