Need some advice.I have a 1987 90hp yamaha 90etlh.I just replaced the shift rod and impeller.Reading this forum was a great help.(only broke 2 bolts)Also cleaned all water passages.Motor runs great.My problem is that when I throttle down it will sometimes stick at about 1/8 throttle.The cable returns all the way.When I disconect the oil pump linkage it works fine.Seems like the return spring is weak.
Have cleaned and oiled all springs.Is it a hassle to change the spring or should I replace oil pump or disconnect it and mix fuel?
Thanks for any help.
