Re: OIL PUMP ON YAMAHA 150 ELTD 90 MODEL
Yes, that is what I'm saying. I just posted a similar response on another thread. I had this washer get out of place and it caused the slide to stick in a position that indicated low oil, this caused my oil pump to keep running and it would overfill the tank. I am guessing that the opposite could happen where it could keep the slide in the opposite position. I'm not guaranteeing this is your problem, but what the heck, its worth a look. The washer wouldn't be blocking the flow since you said that the manual fill switch works.<br /><br />I didn't think you needed a special tester, I though that you were just measuring resistance so an ohm meter would work. I'll have to look at my manual again.<br /><br />Bleeding the pump is easy, although I think you might be confusing which pump is to be bleed. They are referring to the pump on the engine that sends oil to the intakes. What they are saying is that if you had to use the manual switch, you might have ran your engine oil tank low and pulled air into the system. There is a bleed screw on that pump, just be sure to get a rag under it.
