Oil Pan Gasket Mercruiser 160
FreeBeeTony
I am in the process of rebuilding a late 60's Mercruiser 160HP 250cui GM IL6. I am up to the point of installing the oil pan gasket. The new gasket came in 4 pieces. The side pieces are felt and the end pieces are rubber. The end pieces seem to overlap the side pieces? Should I trim the felt so the 2 pieces meet and use a sealer?<br />I am confused at this point. I don't want to make an error and have a leak! Any help here would be greatly appreciated.<br />Thanks in advance.....
Re: Oil Pan Gasket Mercruiser 160
Yep, Trim to fit,+ Seal with Ultra-Black Silicone....
FreeBeeTony
Do I use the ultra black on the rubber portion also?
No, Only on the joints....
