Re: Oil Mixing
Over time various systems have been marketed. Ones that sat in the tank and ones, that by variable injection made the proper mix.<br /><br />Some that run these smart systems have problems and simply do not use them.<br /><br />Anyway, by mixing it your way, you're the master and knows that the motor get's lubricated.<br /><br />The biggest demand on lubrication is when idling because the fuel flows very slowly thus providing very little oil. When running higher rpm more fuel gets in and the oil is plenty.<br /><br />The automatic systems are better comfort and you can get fuel from stations that do not sell your preferred oil, but apart from that there is no great difference for your motor.
