oil leaking when start (yamaha waveraider)
mdizzle
OK, I havn't really looked at or into it yet but I got a 95-97 yamaha waveraider... It had just been sitting in a building for several years but I took it out and got it going for a friend. I got it running and noticed a lot of smoke comming out of the back and there had been oil goin everywhere.... I looked inside and couldnt find any oil its just around the bottom in the back... can anyone tell me where its comming from or how to fix it?
sloopy
Re: oil leaking when start (yamaha waveraider)
If it was winterized the oil and smoke you are seeing is a from the fogging oil burning off (lots of white smoke). Also those two stroke pwc;s are extremely smokey and usually leave a little oil mark on the water when they first start up. Also they smoke a lot more when they are not in the water. <br /><br />MAKE SURE YOUR OIL TANK IS FULL AND THAT IT IS USING OIL!!! <br /><br />Make sure your gas is in good shape to, if it is old gas dilute it and run it in your car. <br /><br />WELCOME TO IBOATS!
Jeff Walkowiak
It could be just residual 2 stroke oil from the water box, and stale gas so I would drain the fuel and replace it, then take it out and run it for a while it should clear up
harveje
Mine smokes pretty bad too. I've heard it the nature of the beast. They are a constant flow oil system.
