Shooter B
- Jun 19, 2011
- 3
I replaced the water pump assembly in the lower unit of my MerCruiser Alpha 1 sterndrive. The boat was running too warm so I decided to investigate and found the water pump trashed. Put in an entire new kit, lubed everything up and installed the lower end back on the drive. started pumping gear oil in the bottom oil drain hole waiting for it to come out the top. It never did! Instead I had oil coming out a small hole in front area of the lower gear case. what gives? Any info will be greatly appreciated. Thanks, Ben.
