Oil leaking in lower unit OMC Cobra
JTLEWIS61
I hit a rock or something last week in my boat. I have used it twice since then. Now I have gear oil leaking from the prop area. Since I keep the trim up while its in my garage the oil collected in the lower unit. I took the prop off and don't see any visible damage. Any suggestions
Bulbash
You should pressure test the outdrive to find a leak. Also, you probably have oil and water mix in the outdrive...
