I have an '87 DT 40 two stroke that has started to leak oil from the exhaust, some from the upper exhaust port but mostly out through the prop. It does this when just sitting and not running. Based on the smell and color I'm sure it isn't lower unit oil. Have not been able to start it since I noticed the leak, lower plug is very wet and oily. I'm considering changing the check valves between the oil pump and the injectors. Does anyone know if the pump has internal seals designed to stop the flow of oil when the engine isn't running? I assume the check valves are there primarily to stop oil from being pushed back towards the pump, but maybe they also stop it from gravity feeding into the intake/crankcase. Thanks.
