Salmonseeker
- Jun 11, 2005
- 298
I have noticed 2 stroke oil leaking from my motor. It seems like it is leaking from the VRO pump or the Carbs. It then runs down the motor housing and into the shaft that attaches the motor to the motor mount.(The shaft that allows the motor to swivel left and right, not sure what the name of this part is.) The oil then seeps out and runs down the lower outside casing of the motor.
This is most noticeable when the boat is not used for a few weeks. The motor is stored in the down position on the trailer. It is definatelly 2-stroke oil leaking out.
Any ideas what would cause this? One guy told me that Oil leaks into the carbs on later model VRO's between trips.
Is this true? what are the reason's for this?(If it is true.)
Thanks in advance, Jay
