I found comments that my 90 HP Johnson outboard leaking oil out the exaust at prop is normal and not to worry. In my case, if the motor is left unused for a couple of months, it will not start. Had a tech open the four brass screws by carbs and clean them out - they had oil packed in the holes. This has happened twice in the past year. The primer bulb stays tight on the oil tank all the time and I was told by the tech that it is the constant oil pressure that is causing the problem. I am thinking of installing a cut off valve in the oil line before it gets to the motor.
Anybody have suggestions?
