I have a nice running-somewhat heavy smoking at low speeds-2000 150 h.p. two stroke Johnson.The issue I have is that it does seem to use a lot of oil especially at lower R.P.M.s.The other issue is, oil leakage after shut down.I am not sure if this is residual oil unburned and committed from oil tank or there is some area on the motor I could inspect for leakage.Are there any adjustments that could be made to the VRO system to make it more efficient and less smokey. I have spoken to other owners of same engine and they have expressed similar experiences.Thank you Andy
