My 1975 Evinrude 75hp leaks oil through the prop when the motor is off in the down position, I have just noticed this and haven't had it in the water yet. I did run it with a flush kit and the leak did not appear to be excessive. What causes this and how do I fix it? Also the prop nut sheared off at the front of the thrust bushing, I drilled out the shaft and tapped a 3/8" x 3/4" bolt and it holds the prop tight against the shaft with a locknut and washer. Has anybody had this experience before, and does this sound like a decent fix?
