jack7771
- Jul 10, 2005
- 83
Re 1986 Evinrude 110 hp
Well, I thought I had a lower gear case oil leak due the bottom screw and washer.
But, I have a more serious problem than a washer. The TRUE oil leak is coming out the bottom of the hub where the prop is.
I took the prop off after seeing an oil line down the back of the skeg, and yep, somehow the lower gearcase oil is coming out there (of course, the real leak is inside the hub up front in that dark cavity somewhere). Drat. How easy is it to fix this problem?
Jack
Jack
