z00m
- Jul 9, 2014
- 21
Hi there, I have been a long time reader but only just joined the forum as now I have my own boat. It's an old girl and needs some love and I thought I would start with trying to resolve an oil leak that dirtied the bilge over quite some time from what I can gather. When I got the boat there was about a litre of oil in the bilge and the bilge is heavily encrusted with dried oil and goo. The problem is compounded by a water leak at the transom but I'll deal with that next. It has taken many trips to the recycling station with watery oil bilge goo and many oil soaker mats but I am starting to see clear water in the bottom of the boat.
When looking over the engine and using a mirror to see where my head doesn't fit, what I thought would be leaking oil pan actually seems to be an oil leak quite high up on the back of the engine. The most oil is around the oil pressure sender location.
The engines are 5.0/LX with alpha 1 gen 2 drives according to the numbers:
Engines – 0D447372/0D447341
Transoms – 0D540420/0D540421
Drives – 0D492823/0D492824
I wanted to order the parts for replacing the oil pressure sender but I ran across a bit of a snag in that there is an elbow to make clearance for the distributor (I'm guessing) that is no longer available. Can anyone point me to the right path for what the replacement items might be? There is no superseding part number so I'm a bit confused.
My engine has the ignition module on the exhaust elbow and the three part numbers for the sender are:
It is part number 46932 - Elbow that is no longer available.
Anyone have any idea what I need to do?
Cheers,
Mike.
Perth, Western Australia
1991 Bayliner 3055
| 13 | 815425 | 1 | SENDER ASSEMBLY, Oil Pressure |
| 16 | 46932 | 1 | ELBOW |
| 17 | 42554 | 1 | NIPPLE |
Cheers,
Mike.
1991 Bayliner 3055
