oil injection
sjtryhard
Have a 115 v-4 yamaha not oil injected. want to convert or make it oil injected Does anyone know Can this be done? Have mixing trouble all the time thnks
butlp
Re: oil injection
sjryhard,<br />Welcome to the Board!<br /><br />Wow! This is the first time I have heard someone want to add oil injection to their outboard. Most people are talking about pulling it off and mixing their gas.<br /><br />I am certainly no expert, but I don't think it would be very particle to install oil injection on a non injection motor.<br />The Yamaha injection system is one of the best, but it is quite complicated and even if you could find all the external parts, I'm sure there are internal differences between non and injected motors. <br /><br />I would mark up a clear oil measuring bottle and continue to mix your gas. It's a lot easier and more reliable than a "bodged up" injection system. IMO.<br /><br />Sorry I can't be any more help, Good luck!
mlkmn8
Re: oil injection
I will say if you dont have oil injection dont get it. Mix your gas/oil it is more reliable.<br />Dont get me wrong oil injection is nice if it works but if it goes out while your on the river then your up the crick without a paddle. At least when you mix it manually you know if your engine is getting gas its also getting oil
