Re: Oil Injection
Yamaha unlike OMC and Mercury, injects their oil after the carb and doesn't mix it into the fuel. This means the carbs are jetted for a straight fuel only mixture. If you go mixing your oil with the fuel, it changes the weight of the fuel and you run the risk of running a cylinder lean. Now they do make the C model that doesn't have the injection, but the jets are different sizes. One day JB, you need to get out of the stone ages and at least update your thinking to the 90's. Folks use to remove the electronic ignitions that started coming standard on the cars in the 70's and changing them back to points due to not understanding the systems and was afraid of it leaving them stranded somewhere. Didn't sound like a bad idea back then, but now we know it was a crock.
