I have a Yamaha 150 early 90's and the oil tank on engine will run down to the point that the warning buzzer goes off and i have to fill the engine tank using the remote switch. I pulled the oil line lose from the aux.oil tank at the aux. pump. when I turn the ing switch on it pumps but only a little faster than a dribble. my question is how much flow should be coming out when the pump is running?
