Re: oil injection removel
I am no where near as knowledgable as others on this but it is my understanding that with the oil injection your engine is much, much better lubricated at recommended levels. When you increase rpm's the injector automatically adds the required amount to meet the needed lubrication under a load. When it is idling it will automatically adjust the oil less helping to keep your plugs from fouling and helping your engine run cleaner and more efficient. The premix won't do that. As Rodbolt said, why mess with a good thing? There's no way you could improve this system by premixing. Also keep in mind there's a lot of guessing when you use premix. How much fuel is left when you fill up? How much oil should you add? Will you always remember to add oil? If a buddy uses your boat will he remember? You may also be removing some safety features that send out a warning if the lubrication isn't enough. So again, why remove it? Hope this sheds some light. Good luck.
