Re: oil injection removal
Yes, it can. Normally the problem is just the filter clogging the slide. It is easy to get at so is quick to fix.<br /><br />There are many pros and cons of removing the oil. It's a tough call. No petrol/oil=stuffed motor, however, one cause of petrol/oil starvation is gummed up carby caused by using premix. Since the oil injection is after the carby this doesn't happen when using injection. Since the carby was designed for petrol only it does have some small channels making it more susceptible to gumming up.<br /><br />I note some conservative users use both. They run a 100:1 or 150:1 premix and use the injection. If you do go the premix route you do need to be more careful with stuff like drainging carbies when not using your boat for a while.
