Re: Oil Injection problem
Is the oil tank on the engine completly full to the top. There is a little hose on the top of the oil tank that goes to the air box is there oil in it? If yes the most common failure is the oil control module with the switch on it below the tank the up dated one has a gray harness on it. If the little hose does't have oil in it. You need to check to see if the oil is being feed thru the oil pump from gravity. Vinney
