oil injection or not?
joonch65
I just bought a used 70 Johnny that has oil injection. The guy I bought from said he still mixed his gas and used the injection at the same time. Huh?? Is it safe to do away with the injection and just mix the gas manually? Also what does VRO stand for? Thanks,j.
fitzms
Re: oil injection or not?
I believe VRO stands for varible ratio oil injection.Somebody crrect me if Im wrong
Solittle
One of the first thing I did when I bought my rig with 1987s on it ten years ago was to replace the VRO pumps with regular fuel pumps. I use pre-mix and have no problem with mixing fuel & oil in the fuel tank. I never have to wonder if the VROs are working properly.
marinemech
if you don'y want to use the oil injection remove oil line cap off fitting and disconnect wires
joonch65
cool thats what i wanted to hear. i dont even want to put the oil tank in my boat. just takes up valuable space!do i need to change the fuel pump? i would rather mix it manually and not have to worry.thanks j
