davidrochford
- Jul 2, 2001
- 12
I have a problem with my 1998 Mercury 150XL. I ran it about an hour Saturday and it ran fine. Then the oil warning started beeping. Temperature was fine at 140. Adjusting the throttle would get the beeping to stop for a little while but then it would come back. I suspect a sensor problem. I think the engine is getting oil OK. The only reason I don't disable the oil injection right now is that I have a 4 stroke kicker and I want to use the same tank for it. Does anyone know what would happen if I had to run the 4 stroke kicker on 50:1 in an emergency? What do you guys think I should do? Disable or fix?<br /><br />------------------<br />David Rochford<br />david@zesco.com
