Re: oil in the piston
common issue with the older rotax engines the rotary valve compartment is between the 2 cylinders,, this has seals to keep oil on the rotary valve shaft, usually the crank seals leak and oil gets in the crank case causing the engine to smoke like crazy after it has been sitting for days,, you actually have to rebuild the lower end to fix it, or remove the plugs and crank out the oil,, then start it and it will stop smoking in a few minutes,, but it will do it again after it sits a few days.
