I was addressing my timing, carb linkage and adjustment on my '87 6hp in a garbage can. After a good hour or so of combined running I had quite a bit of oil in my garbage can. Seemed thick like the gear case oil, but I am not sure. Is that normal or does that indicate I need to change out the seals?
My manual states to pressure test the lower unit with 19 psi and also pull a vacuum to insure no leaks. I have yet to do that or even check the oil level for water. Before I tear into it, I wanted to know if some oil in the test tank is normal or not. It could be two stroke oil but I am not sure.
Thanks,
Paul
Thanks,
Paul
