Oil hose length, Bravo 1
Speakrdude
Ensign
Anyone know the oil hose length for a Bravo 1, 92ish model, This the hose that connects from the gimbal housing to the bell housing.
Jim
Fun Times
Re: Oil hose length, Bravo 1
I don't recall the "actual length" of the hose off hand, but it is a cut to fit if you end up buying original hose. See item number 7, you buy the hose in bulk so you could replace both the inside of the boat and outside if needed.
http://www.mercruiserparts.com/Show...sc=OIL+RESERVOIR+COMPONENTS(ROUND+OIL+BOTTLE)
Take it for what it's worth, but Google finds it to be 9.5 inches,
http://www.offshoreonly.com/forums/drives-lower-units/257455-bravo-1-drive-oil-hose.html
9.5 inches seems to be about right though, Good luck.
