Re: oil/gas mixture old evinrude
thanks Howdy.I dont know how long it has been since this engine has been ran.I took out the plugs and sprayed some WD 40 in the cylinders. while I had out the plugs I checked the sppark and had a strong spark on one and none on the other.I think its the points but that is a small thing.It also seem to have high compression which is good should run good. Tanks!!!!!!!
