oil gas mix ?
lynnboy021
someone told me that my waverunner runs 93 and 40 to 1 so i filled it up with 5 gal 40:1 but my manual says i have to use regular gas and 50:1. so my ? is will anything happen running 93 40:1? and if 93 is ok how can i make 40:1 to 50:1 with out starting over????
DoGood
Re: oil gas mix ?
if the engine is stock then it doesn't matter whether you run 89 or 93 octane. Save your money and run 89.
To change from a 40:1 to 50:1 mix you just need to add 1.25 gallons of gas to the 5 gallon tank. Personally, the difference is so small I wouldn't worry about it. A little more oil will not kill a stock engine.
Now if the engine has a high compression head on it you may need to run a higher octane gas. If someone that knew it had a high compression head on it, and knew the compression then they may be right and you need to run 93. Or they could just think the a higher octane is always better. I start by checking the compression. If it's around 150 regular gas is fine. If it's much high like 170+ you'll need more octane.
The Penguin
Re: oil gas mix ?
you aren't harming anything by running 40:1, just a bit of extra lubrication.
the only side effect you may experience is that your plugs foul more often - but that really depends on how much low speed vs. high speed running you do on the motor.
if it's in a sit-down - they tend to run longer at higher speeds, so plug fouling will probably not be an issue.
ditto on the 93 octane - only necessary if you have increased compression.
lynnboy021
Re: oil gas mix ?
sorry guys another ? um i have a pipe next to the prop with a hole in the middel any idia
The Penguin
Re: oil gas mix ?
I have no idea what you are even asking.
post a picture, please.
