2000 Merc 3.0 Alpha 1 Gen2<br /><br />About to change the oil. After reading many threads here, and this oil page on Mercury's site, I have come to the conclusion that Castrol HD 40 would be ok to run. If I'm wrong, please correct me.<br /><br />I am a bit low on tilt fluid. Can anyone tell me if power steering fluid is kosher to use here?<br /><br />I also need some info on lubing the out drive. I count 3 fittings. One right by the transom on the starboard side, and one on each side by the tilt parts. How can you tell when they are full? I'm used to seeing some grease come out when I lube my truck and the trailer.<br /><br />Thanks and sorry for the oil questions!<br /><br />Tom
