oil filter cross reference
mregehr
I need to change the oil on my 1988 Regal, which has a GM/Mercruiser 4.3 l V6. Anyone know how to figure out which automotive oil filters will fit? I bought one for a 1988 Chevy Astro and it doesn't look right.
extreme76
Re: oil filter cross reference
I know on my 99 4.3 I use the same one that would fit a 99 S-10 blazer with a 4.3l. I use Wix-51036, however that appears to be the same one that would fit an Astro van. It works in my '99.
mregehr
Thanks. Why WIX? This is the first I've heard of that brand and it looks like they're a little harder to get (e.g., Pep Boys doesn't have them) than Fram or Purolator. Do you think WIX makes a better filter?
Oldskool
WIX and NAPA Gold filters are identical, so you can get what you are looking for at any local NAPA Auto Parts store. Simply drop the first digit off of the WIX part number for the corresponding NAPA part number. WIX 51036 equals a NAPA 1036. If you cut open a FRAM and a WIX/NAPA you'll see a big difference in the quality between the two. With regular oil and filter changes, either one will protect your engine.
Alpheus
short length 4.25" filter (oem):
Sierra 18-7879
Aquapower 6004
K&N HP2001
AMSOil SDF23
ACdelco PF51, 52
Napa 1036, 1040, 1190, 1340, 1387
wix 51036, 51040, 51190, 51340, 51387
Motorcraft FL-402
Purolator PER111, 112, 173, 307, 1091, 4011; L24011
FRAM PH3980
long length 6.25" filter:
napa 1286
wix 51286
ACdelco PF1406
