Oil Filter Bypass Lines
f_inscreenname
I have a remote oil filter with two hoses that brings the oil from the filters normal location to the remote location.
The question is, what kind of PSI is in these hoses under normal operation? The gage on the dash is reading 55lbs. Is it the same in the hoses?
Re: Oil Filter Bypass Lines
Ayuh,..........
Oil Pressure is Oil Pressure............
f_inscreenname
The lines are rated for 250lbs so I guess they should be cool.
Thanks​
Ayuh,.........
The Odds that they'll Ever see the other side of 100psi is Pretty Slim.........
f_inscreenname
"Ayuh,.........
The Odds that they'll Ever see the other side of 100psi is Pretty Slim........."
I hope so or I will be blowing gaskets out everywhere.​
