I HAVE A 1990 115HP ETLD MOTOR. I FINALLY SOLVED MY RUNNING PROBLEMS FROM LAST YEAR.
IT TOOK A NEW FUEL PUMP, BALL AND HOSE, ONE NEW COIL, AND SPARK PLUGS TO GET IT RUNNING AT 45 MPH AT 55-5800 RPM ON A 19p PROP.
MOTOR WAS ORIGINALLY OIL INJECTED AND I HAD REMOVED OIL PUMP DRIVE SHAFT, OIL RESERVOIR,
AND LINES AND PLUGGED OIL PUMP HOSE.
HERE'S THE PROBLEM:
BOAT HAS RUN GREAT UNTIL THIS WEEKEND WHEN I THOUGHT I WOULD REMOVE THE OIL EMERGENCY SWITCH FROM ENGINE. I MOUNTED THE TWO GROUND WIRES THAT WERE GROUNDED ON THE BODY OF THE SWITCH DIRECTLY TO THE BLOCK.
WHEN I TOOK THE BOAT OUT, IT STARTED GREAT, RAN GREAT UNTIL I HIT 5000 RPM AT 40MPH. IT MADE A POPPING SOUND AND THEN STALLED WHEN I BACKED OFF THE THROTTLE. MOTOR RESTARTED MANY TIMES AFTER BUT ONLY FOR 15 -30 SECONDS. WHEN PUT IN DRIVE IT STALLED AGAIN. TRIED PUMPING THE BALL WHILE RUNNING TO NO AVAIL THINKING MAYBE LACK OF GAS. TOOK BOAT HOME AND PUT THE EMERGENCY OIL SWITCH BACK ON MOTOR AND HOOKED UP WIRING HARNESS. IT STARTED IMMEDIATELY AND RAN GREAT FOR AT LEAST 10 MINUTES. PUT IT IN BOTH FORWARD AND REVERSE GEAR AND IT STILL RAN GREAT. SHUT IT OFF AND STARTED AGAIN WITH JUST A TURN OF THE KEY. LET IT SIT ANOTHER 15 MINUTES AND IT STILL STARTED. DISCONNECTED THE SWITCH WIRING HARNESS AND MOTOR RAN JUST AS GOOD AS IT DID WITH HARNESS ATTACHED.
BIG QUESTION:
IS THERE A WIRE ON THE EMGERGENCY OIL SWITCH THAT CONTROLS THE WAY THE MOTOR RUNS ?
IF NOT, WHERE DO I LOOK TO SOLVE THIS PROBLEM?
HERE'S THE PROBLEM:
BIG QUESTION:
