oil driping from carborator
j.p.h.
35 hp has problem with oil driping from carb 100# p.s.i. compression mortor starts rite up carfull meatered oil to gas ratio
fireman57
This is normal especially when you tilt it for traveling. If you have no issues with it running then don't worry about it.
sutor623
You think thats bad you should check out the carb drip from 1970-80's mercury's!!!
