what is the best equipment to use to change the oil on a 260 hp mercruiser engine? is the vacuum system on the 1 gal can good? or should I buy the unit that has the 12 volt impeller pump on the top of a 5 gal bucket? I have always dreaded this job and usually end up with oil all over the place.Right now I am using a small plastic 12v pump that draws the oil out of the dip stick.Does it matter if you remove the filter first then suck the oil from the pan or the other way around?<br />I usually take the boat out for a good run first but even then after the oil change the new oil sometimes looks contaminated.Is it a good Idea to add a few ounces of marvel mystery oil just before changing the oil to help get all of the old oil out? any sugestions to make this job easier would be greatly appreciated. Also does it make a difference if you use an auto filter? I have been using shell rotella oil its suppose to be good for marine engines.
