Oil Change
Roller
I just bought my boat and its a 2002 Reinell wth a 5.0 L merc inboard and I,m just curious how you drain the oil out the back or what you do I havent really climbed down under there to have a look as it is kind of an aukword area so I though I would ask first.
Thanks for any helpful hints.
QC
Re: Oil Change
Welcome aboard Roller!! I moved this over to the I/O section. You'll get the best answers here . . . ;)
AZSenza
Re: Oil Change
I'm betting that you have a oil dipstick with large threads on the top of the tube, this is for a handhelp pump to screw onto. You suction the old oil out. Its really a cleaner meathod and gets 99% of the old oil out, just do your best to make sure the oil pan is level by adjusting the attitude of the boat with the trailer jack.
Begester
Re: Oil Change
That handheld pump will be the best $15 you'll ever spend. I did an oil change on my boat in less than 20 minutes yesterday and didnt get dirty at all.
Make sure you are on a flat surface.
Schmoe
Re: Oil Change
I got a hand held pump for my 3.0, best thing since beer for oil changing.
ken_23434
Re: Oil Change
Welcome to the forum.
If you trailer your boat, I like the remote oil drain hose (that's my name for it).
Basically, you will get dirty the first time, but after that, you are clean.
The kit will have a banjo type fitting that goes in place of the existing drain plug. It will have a length of hose attached to it that has another plug at the other end. When it's time to change the oil, you pull the hose out the drain plug at the back of the transome (the one you drain the water out of the bilge from). Once the hose is dangling out the drain hose, you unscrew the fitting at the end of the hose and direct the oil out to a bucket. This has the advantage of ensuring ALL the oil is drained from the engine, plus you are draining from the bottom, so you are ensuring you have gotten any crud that has settled to the bottom.
If you boat stays in the water, then the hand pump method mentioned before is your best bet.
cooter2506
Re: Oil Change
I agree with Ken I use the hose too and love it. It is slow but if you open the the oil cap on the valve cover it does come out faster.
SeaVue
Re: Oil Change
Thanks a lot Gary. Seems like a good idea. I'll give it a go. :D
Gary H NC
Re: Oil Change
If get the Napa one it is in their marine parts book.Made by Balkamp...;)
With the motor warmed up it works great.....
danfrompgh
Re: Oil Change
I'm not trying to hijack your post but I have a question on the same issue. My 5.0 has the regular old style dipstick tube not the screw on cap w the dipstick attached like some others. How far does the dipstick tube reach into the oil pan. Someone told me I could attach the suction tube from my oil drain pump directly to the tube and remove my oil. The directions from my pump say to insert the pump tube into the dipstick tube to remove the oil which didn't work so well last year.
Boats coming out of storage next week....finally :D
windsors03cobra
Re: Oil Change
^^ Those type of dipstick tubes usually dont go into the pan at all, stick the pumps little tube into the dipstick tube.
Jeepster04
Re: Oil Change
Yup, weve got a pump where you just stick the hose all the way down into the dip stick hole and pump away. Usually we bottom the hose out on the bottom of the pan then lift it up just a hair so we know were sucking off the bottom.
Got my pump at harbor freight. Its not the best in the world but it was only $30 or so. It has two sections of hose. The first hose was too big and thin so it would suck together from the vacuum. The hose that went down into the dip stick was nice and thick so I cut the thin hose off and put the thick hose right on the pump... Works great. :)
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=45403
Rocky_Road
Re: Oil Change
Does anyone have a picture of the pump that 'screws' to the top of the dipstick tube?
Even though I normally use the hose that is attached to my oil pan, I am considering using the dipstick method....
Gary H NC
Re: Oil Change
Same threads as a garden hose...any hardware store has the ends for a couple bucks each...
Roller
Re: Oil Change
Thanks guys for all the help I will pick up parts and pump to give it a try!:)
