oil change???
Clay Resmondo
I have a 1975 Sears Ted Williams (Eska) 5.5 (mod.# = 217.58571.0) and the motor is a Tecumseh (mod.# = T643-20B). I am wondering about changing the oil, i see the drain plug but where do i refill at and how much do i put in, also what wheight oil should i use? any help would be great thanks. ( sears website does not say)
steelespike
Re: oil change???
The plug is a drain and fill plug.lay it on the side to drain.Stand up at a slight angle with the plug up to fill.Fill to the hole with outboard sae 90 gear oil.
Clay Resmondo
Re: oil change???
Thank you steel do you or anybody else know how much to put in? thanks.
CATransplant
Re: oil change???
It's not a lot, but I don't know the exact amount. If the hole is on the side of the gearcase, fill it, with the engine upright, like it will be on the transom, until oil begins to come out of the hole, then re-insert the plug. That'll do it. Take your time. It takes a while for the heavy oil to fill all the spaces in the lower unit. Fill, stop, then add more.
