oil back bleeding in to inline filter
nice-diver
1992 johnson 40hp vro
Now that I have a clear fuel filter; I can see oil that drains back into the inline fuel filter.
I store the fuel tank in the garage, so the the fuel line is left in the boat.
Is this normal or DO i really have a vro pump failure, about to fail.
thank you
tashasdaddy
Re: oil back bleeding in to inline filter
get rid of the VRO pump and install this premix pump.
http://www.iboats.com/Fuel-Pump/dm/*******.018270172--**********.885845114--view_id.174141
directions: VRO to 2 line pump
http://www.iboats.com/Fuel-Pump-for...432451-433387-438556-Sierra/dm/view_id.174141
it is a little more complicated than just the pump. using that pump is the correct conversion. on the port side of the motor rear of the starter, you will find 3 bosses, 2 bolt holes, and a plug to remove. this is the mount for the new pump. you will need to block the pulse line from under the carb to the old VRO pump.(just a bolt in the hose, and a hose clamp). remove the Vro Harness and the oil tank harness. reroute your fuel lines. premix your fuel, and you should be good to cruise.
