oil and water temp gauge
jwhitm
i would like to add a oil pressure and water temp gauge to my 150 yamaha 2 stroke year 2000. is this fairly easy where i may do it myself or should i take it to local mech. ?
Silvertip
Re: oil and water temp gauge
You have a two-stroke engine --there is no oil pressure to monitor. Water PRESSURE gauges are easy to install as there is no transducer. You simply "Tee" into the tell-tale or tap into the cooling system through an unused port. Water TEMPERATURE gauges require a sender that screws into an unused port in the water jacket or a contact type sender that touches the cylinder head. Both gauges come with instructions and both are simple to install. Teleflex and Faria both offer them and they are available here on iBoats.
Big Keepers
My Yamaha has a cylinder temp gauge that the factory installed. Yours should too I would think. Granted mine is an '87 it is a small plug that comes out of the starboard side on top of the cylinder.
