phillnjack
- Oct 22, 2003
- 51
i have 60hp mercury 1993/4. its fitted with alarm etc . how do you know if the alarm is working ok as it dont make any noises when the key is turned on. should i get a warning when first put ignition on or not, i know some engines that have alarms sound a beep as soon as you turn the key but mine dont is this correct or have i got a problem. if this is right then what a silly thing to put on any engine as you wouldnt know if working or not. i have tested the temp alarm and the horn does work not tested oil yet though waiting till it gets very low.
