Michael Mullis
- Feb 7, 2006
- 14
I have a 1998 70 hp Johnson,4 stroke, Model J70FTLEC.<br />How many poles does this motor have? I have to replace the Tach and want to be sure to connect correctly. The current Tach, a Faria, has settings listed as:<br />1-4<br />2-6<br />3-8<br />4-10<br />5-12<br />6-20<br />Presently set on 5-12<br />I hooked a DVM to the sending wire and ground and had voltage that increased as RPM was increased so I think the Tach is shot(needle does not move at all).<br />Also, I see a switch(lever type) that is mounted beside the trim/tilt cylinders so that as the motor is lowered the switch is depressed is this a cut out switch? Or maybe for a trim gauge? I do not have a trim gauge on the boat. When I hold it down by hand the trim/tilt will still activate. I do not feel any type of contact action when lever is moved so think it may act as a Rheostat. I will go outside now and see if I can trace wires<br />Thanks <br />Michael
